Problem with recreated project and .au files
chafer444
Post by chafer444 » Fri Nov 20, 2009 10:02 pm
I recently messed up an Audacity project, but I was able to recreate it from a CD I had made when I exported it some time ago. I took the six tracks and converted them the .au files so Audacity could open them. I then put them back together and saved it, but when I deleted the six files I found that I no longer had sound in the new Audacity project, but there is a wave form displayed. When put the six files back on my desktop I got the audio back. It seems the new project is drawing off of the .au files. How do I stop this?
Re: Problem with recreated project and .au files
Post by kozikowski » Sat Nov 21, 2009 12:12 am
Audacity has a preference setting called something like: "Copy all music (Slower)" maybe (Safer). Audacity defaults to leaving all the music right where it is and reference it at the right time (Faster).
The blue waves come from graphics files and can easily get out of step with the show if you're doing manual file management.
You might run into troubles if you're not starting with original uncompressed sound files.....
Give it a shot.
chafer444
Post by chafer444 » Sat Nov 21, 2009 12:25 am
I'm not sure I understand exactly what you wrote, but I did find the place on the File Formats tab to choose the safer option. I'll try doing it again with that one checked. Thanks
Post by kozikowski » Sat Nov 21, 2009 12:31 am
Those English words change a lot depending on which version of Audacity you have.
You know you're doing the right thing because the machine will go into file management mode and the hard drive light will come on for a while as Audacity copies music inside itself. That step is missing if you leave the default as it is.
And, of course, you already know how to move files and make sure that the show doesn't drop dead.
chafer444
Post by chafer444 » Sun Nov 22, 2009 2:03 pm
Thanks, that fixed it.
