Effects doesn´t work, please help!
Carljohano
I Have installed the effect plug-ins and even the file who does the effects aviable, but it still doesn`t work! what have i did wrong ? please help me!
Re: Effects doesn´t work, please help!
Which effects?
Which file?
Which version of Audacity?
Which version of Windows?
Exactly what did you do?
When you do everything right, you still need to restart Audacity before the effects become available.
Which file?
Carljohano
stevethefiddle wrote:Which effects?
Which file?
All the effects even the plug-ins LADSPA-program. I have download the VSP enabler and it still doesnt work. I have Windows XP and Audacity 1.2.6
Ladspa plug-ins do not require the VST enabler, so you can safely remove that.
To install the LADSPA plug-ins, make sure that you have downloaded the Windows version (ladspa-0.4.15.exe) from this page: http://audacityteam.org/download/plugins
This is an installation file which you must run to install the effects.
Carljohano
stevethefiddle wrote:Ladspa plug-ins do not require the VST enabler, so you can safely remove that.
Does it matter if i delete it or not ?
Carljohano
Carljohano wrote:stevethefiddle wrote:Ladspa plug-ins do not require the VST enabler, so you can safely remove that.
Now it works, i didn't understand how to use it first, but it works as i shall, Thanks alot for your help!
