Arre you sure you are using the "Export" command in the File menu and not "Save"?trahcwolf wrote:Tried exporting, and no matter what I do, I am not allowed to save to
any format other than as an Audacity project.
"Save" or "Save as" will only allow you to save as an Audacity project.
File > Export
When you click on Export, you will get an Edit Metadata window with a lot of boxes to fill in. You can click on OK without filling anything in (this just gives you the option to add data to your WAV or MP3 file that iPods or MP3 players can read). Then you will get a window where you select the type of file you want to save as, and where.
If you are exporting in order to listen on an Ipod or MP3 player, MP3 is fine. Every time you export as MP3, the file gets put through the MP3 compression process and the quality suffers, but for everyday listening, most people can't hear the difference.trahcwolf wrote:That's the first time I've heard that MP3 causes some file damage or quality loss
Is Wav a better format?
If you intend to import the file again into Audacity and work on it, export as WAV.
To make a CD, export as WAV signed 16 bit PCM. You will need to bring the WAV files into a CD burning program to burn the CD.
PO'L
