Mp3 stereo to mono
bayoureaper
Mp3 stereo to mono
Post by bayoureaper » Wed Oct 21, 2009 9:16 pm
I have MP3 stereo files I need to change to mono. I'm a newbie to Audacity so please layman instructions. Thanks
Re: Mp3 stereo to mono
Post by kozikowski » Wed Oct 21, 2009 10:41 pm
Do the files play OK right now? They don't play at 5000 times normal speed?
Step one. Install Audacity 1.3. You can have both Audacity versions on your machine as long as you don't use both at once.
Open one of the songs. Tracks > Stereo Track to Mono.
Export new song. You understand that Audacity doesn't edit MP3 files, right? It converts them to a very high quality internal format and makes whole new MP3 files when it's done. This produces double MP3 compression damage. Also, Audacity doesn't edit MP3 without adding the "lame" software to manage the MP3 compression.
http://audacityteam.org/download/beta_windows
bayoureaper
Post by bayoureaper » Thu Oct 22, 2009 2:29 pm
Thanks, but when I go under tracks the stereo to mono is grayed out and I can't click on it.
Post by steve » Thu Oct 22, 2009 6:05 pm
Are you sure that it is not already a mono track?
bayoureaper
Post by bayoureaper » Thu Oct 22, 2009 7:37 pm
Under the song heading it says stereo 44100Hz
Post by kozikowski » Thu Oct 22, 2009 7:50 pm
Does it look more or less like that...
http://kozco.com/tech/audacity/Audacity1_playback.jpg
I think the sound meters may be a different size, but the stereo show should look a lot like that. Are you in Audacity 1.3? You never actually said those English words.
bayoureaper
Post by bayoureaper » Thu Oct 22, 2009 8:15 pm
Yes that's what it looks like. I downloaded 1.3 as instructed it looks different from the the one I was using.
bayoureaper
Post by bayoureaper » Sat Oct 24, 2009 2:16 pm
Hey guys still wandering how to change to mono any help. Thanks
Post by kozikowski » Sat Oct 24, 2009 4:39 pm
Just for grins, pull down this six second stereo piano solo from here...
http://www.kozco.com/tech/piano2-CoolEdit.mp3
Restart Audacity, open up that file and see if all your tools work.
KOz
Post by steve » Sat Oct 24, 2009 7:52 pm
bayoureaper wrote:Thanks, but when I go under tracks the stereo to mono is grayed out and I can't click on it.
The track must be selected.
Click on the information box on the left side of the track, this will highlight the track. Then go to the Tracks menu and select "Stereo Track to Mono"
