Preference Problems
Preference Problems
Can anyone tell me why when I click on preferences I get an MSVCR71.dll was not found error and how to fix it. I did a search on the computer and there are mutiple places on the computer where the MSVCR71.dll is found. Any help would be great.
Re: Preference Problems
I wonder if you didn't get a damaged install. Remove Audacity and pull down a fresh version and start over. We tell people that in spite of all the dire warnings, most people should be using Audacity 1.3. Try 1.3 first. If you don't like it, you can install 1.2 without removing 1.3.
Thanks for getting back to me I'll try that and let ya know.
