I've got a macbook from my school, and last week I needed to hand it in for maintenance. Now that I have it back the short keys are not working. (E.G. before maintenance I could for example pres Fn + F1 to decrease the brightness of the screen)
I know I should contact my school about it, but I was just wondering if anyone had a quick solution which could fix this problem.
P.S the question is related while using my macbook with windows xp.
Macbook windows related question?
Re: Macbook windows related question?
Apple > System Preferences > Keyboard and Mouse > Keyboard Shortcuts
Try Restore Defaults. Or at the bottom of that list is the Screen Brightness controls. I don't need the Fn key. My screen brightness goes up and down with straight F1 and F2. You may have had a special setting and the default is no Fn key.
I seem to recall at first birthday the machine asked me if I wanted the F keys or the alternate functions as default. So that's a setting somewhere.
