playback speeds way too high
annaboom
Post by annaboom » Fri Nov 09, 2007 8:19 pm
I just installed Audacity for Windows (XP), and re-installed, but the problem persists : When trying to playback imported music, the song flashes by in an instant, making just a terrible screeching sound.
What may be the problem here?
Thans for your help.
Annaboom
richardash1981
Re: playback speeds way too high
Post by richardash1981 » Fri Nov 09, 2007 9:20 pm
The file your are importing is not in a supported format - see this FAQ:
http://audacityteam.org/help/faq/faq?s= ... roprietary
annaboom
Post by annaboom » Sat Nov 10, 2007 9:36 pm
Thanks Richard.
That was indeed the case. Importing MP3 was no problem at all.
ElaineTulsa
Post by ElaineTulsa » Sun Jan 11, 2009 9:23 pm
I have a similar problem. I was able to record a song from a 78rpm album onto my iTunes but the length of song was totally different. Itunes shows song length as 2:58, song length on album is 6:04. I did save the song as a WAV but when I play it on my iTunes, it plays in warp speed.
Post by Gale Andrews » Mon Jan 12, 2009 7:13 am
ElaineTulsa wrote:I have a similar problem. I was able to record a song from a 78rpm album onto my iTunes but the length of song was totally different. Itunes shows song length as 2:58, song length on album is 6:04. I did save the song as a WAV but when I play it on my iTunes, it plays in warp speed.
Are you on Windows? This is nothing to do with failed installation - you did install Audacity...
Did you record the disc at 78 rpm or does the turntable only play 33 1/3 rpm? If it only plays 33 1/3rpm did you apply the correct speed change in Audacity? Is it the correct length and speed in Audacity before you export it as WAV? Do we assume this is two sides of a 78 rpm pasted together?
