WILL NOT RECORD .. NEW USER
TIKA
Post by TIKA » Mon Oct 12, 2009 7:27 pm
When I get a edit done and want to record it, it shows a flat line in recording. When I play it back .. there is nothing there. I'm new to this. I don't know if I changed something or what? I uninstalled it and it still does it. I then reset the default settings as it said. Still no recording. What have I done? Is it possible to fix this? I clicked on the mic bar on top one time before. other then that .. I'm not sure what I did. PLease help ...
Re: WILL NOT RECORD .. NEW USER
Post by kozikowski » Tue Oct 13, 2009 4:00 am
We can't tell from the posting what the problem is. Audacity used to work just fine and one day you lost your show? New live performances stopped recording? You saved your work and it vanished?
