We only had one jack to transfer music from a cassette tape to a digital recorder. So now we only have one channel recorded. We'd like to just duplicate everything from the existing channel onto the empty channel, but can't find instructions on how to do this. If I use the copy/paste or duplicate commands it just creates another set of channels. How can we accomplish this?
Thanks much! And thanks for this great open source software. We thought we'd have to wait months to afford software like this.
Duplicating one channel onto the other
Re: Duplicating one channel onto the other
<<<So now we only have one channel recorded. We'd like to just duplicate everything from the existing channel onto the empty channel>>>
Tools On The Left (under the arrow) Split Stereo Track. Copy and Paste. Make Stereo Track.
Thank you, thank you, thank you. Worked perfectly, once I figured out that you meant that I should click the little arrow that's above the "Mute" and "Solo" buttons.
