I can't find the defaults button for get rid of every changes I made. Where is it?
Thanks for help me.
Davide
How I can reset AudCITY defaults?
Re: How I can reset AudCITY defaults?
You hit the gold standard for difficulty. Windows Audacity 1.2 keeps its preferences in the Dreaded Windows Registry. The only graceful way to "reset" this Audacity is to de-install it completely in the control panel and reinstall it.
If the New Audacity does not ask you "English?" at First Birthday, then the Registry values are stuck or damaged and you need to use the more serious Registry Edit Tools.
...that I can't find. I know we have a write-up on this somewhere.
Looking.
Looking.
No, that does not reset the preferences. The preferences are still retained.kozikowski wrote:The only graceful way to "reset" this Audacity is to de-install it completely in the control panel and reinstall it.
The best way is to use the "safe solution" that is described in the page that koz has posted the link for.
