autotune for audacity
fookleburgers
Post by fookleburgers » Wed Sep 30, 2009 7:54 pm
Hi, im kinda new to these forums, and i know everyone asks about this... but i cant seem to find the information no matter how hard i look. I would like to know if there is an autotune program compatible with audacity. I dont know anything about it, so detailed instructions on where to get it, how to install it, and how to use it would be sooo loved! thank you!
Re: autotune for audacity
Post by steve » Wed Sep 30, 2009 10:08 pm
Antares AutoTune may work with the latest version of Audacity 1.3.x
It did not work with earlier versions of Audacity, but there have been some big advances in plug-in support recently.
Autotalent by Tom Baran is compatible, but it is only available as source code and instructions are limited. (if you are able to build it from the source code, then using it is very simple) http://web.mit.edu/tbaran/www/autotalent.html
