Audacity has stopped working.......
crazyfooinc
Hey everyone, I need some help. When I download audacity and install it, everything is fine; however, when I try to run the program it says this, "Audacity.exe has stopped working, windows is looking for a solution to the problem." Then, it closes out and I am unable to open it
. I am running on Windows Vista 64bit. Thanks for your help!
(audacity 1.2.6 stable)
Re: Audacity has stopped working.......
I'm not a Windows elf, but I can hear them telling you to download and run Audacity 1.3. you can put both versions on your machine as long as you only use one at a time. Audacity 1.3 projects will not open up in 1.2.
Audacity 1.2 was written during the Harding Administration and can't cope with the modern operating systems and computers.
crazyfooinc
Thanks, I'll try that now
crazyfooinc
Thanks! It worked! Now to find a tutorial lol
Checkout the "Tutorials" link at the top of this page.
