Hi,
im not sure if this is even possible? i dont have a record out or booth out on it (pioneer DJM300) - i have a master out, L and R for both channels - so 4 inputs. i bought a twin RCA - mini jack (6.5mm) lead, and have connected two of the 4 inputs at the back of the mixer into the line in on the pc. when recording, nothing is coming through.
im sure this is a simple case of me not understanding the connection properly. do i need a different cable, or an amp/speakers to connect from the PC instead?
cheers
connecting to 'master out' on a mixer, no speakers
Re: connecting to 'master out' on a mixer, no speakers
Three problems and counting.
The connection to a PC is a 3.5mm stereo plug. The adapter for this (never having seen the mixer before) is RCA (white and red) to 3.5mm stereo plug, similar to this...
http://www.bhphotovideo.com/c/product/3 ... Cable.html
The Plug goes into the Line-In of your Deskside PC or Mac (generally not PC laptop) and the RCAs go into the Line-Out, Main-Out, or Mixer-Out of the mixer.
You have a PC Laptop, right?
Hi,
"The connection to a PC is a 3.5mm stereo plug."
oops - sorry, i actually do have that, mis-spelt the size!
would the headphone in be classed as the line in? as there isnt a separate line in (the green port is it?)/there are no coloured ports.
none of the volumes are muted. still get nothing from the mixer though.
