LADSPA Plug-Ins for Windows ( Vista )
Michel
Post by Michel » Thu Sep 17, 2009 9:01 pm
Hello,
How should i proceed ,and what is it i need exactly to install Ladspa Plug-Ins ?
I tried the following program i.E. " LADSPA_plugins-win-0.4.15 " , but after its installation , there was no new plug-ins appearing at all in Audacity's ( v. 1.3.9 ) menus .
Many thanks !
jademan
Forum Crew
Re: LADSPA Plug-Ins for Windows ( Vista )
Post by jademan » Fri Oct 09, 2009 5:32 pm
Michel wrote:Hello,
Many thanks !
Michel,
To reduce overhead, Audacity 1.3.9 no longer scans the directory for VST plugins every time it is started. To rescan for VST plugins, go to Edit > Preferences > Effects, and check "Rescan VST effects next time Audacity is started". Then exit and restart Audacity. I don't know if this works for LADSPA, but it is certainly worth a try.
If this doesn't fix the problem, try re-initializing your .cfg file. See Where are Preferences stored?
I hope this helps.
