Recording sound directly from PC
LordHoodles
Post by LordHoodles » Tue Sep 15, 2009 4:29 pm
If I play a video through YouTube or a song through Windows Media, I can't get the Audacity programme to record it. I'm using version 1.3.9, and I've tried to follow the instructions on the other post for this sort of thing, but they don't work.
My Devices section (there is no Audio I/O section that I can find in Preferences) is set thus:
Interface Host: MME
Playback: Microsoft Sound Mapper - Output
Recording: Microsoft Sound Mapper - Input; Channels: 2(Stereo)
On my other computer I have version 1.3.8 and it works fine from there, with the exact same settings. Can't get it to work on 1.3.9 though.
Any ideas?
Thanks,
Hoodles.
Re: Recording sound directly from PC
Post by steve » Tue Sep 15, 2009 5:11 pm
What operating system are you using?
Can you record anything? (for example, microphone?)
Have you read this tutorial - http://wiki.audacityteam.org/index.php? ... e_computer
LordHoodles
Post by LordHoodles » Wed Sep 16, 2009 2:43 pm
Using Windows Vista 64-bit, and XP on my other pc. I can record through the microphone on my headphones.
I'll take a look at the tutorial...
Post by kozikowski » Wed Sep 16, 2009 3:35 pm
Convenient internal recording has been carefully filtered out of a lot of newer machines. Macs have never been able to do this and the PC people are starting to see the wisdom of that. Multiple recursive feedback sound pathways get (PC) people into trouble all the time, and it's serious magic when it does.
"How come my recordings change volume and become damaged or feature echoes and background noises."
Which pathways, faders, or switches did you leave open by accident? And it changes with the sound card and computer.
You can use Total Recorder on the PC like I do and the pathways are created for you when they are needed. There may be other programs, but that's the license I have and happily use. If you have a deskside PC, you can also use a short jumper cable between the headphone out and Line-In. Laptops tend to be missing the Line-In.
Another way is to get those connections with an external USB sound card.
http://forum.audacityteam.org/viewtopic.php?f=27&t=9477
