I have a folder of 146 b00###.au files that were the temp files created while making a recording.
The user didn't save the audio as a project or Export it as MP3 but did save the files.
Is there anyway to quickly reconstitude the original audio without cutting and pasting all 146 snippets of audio?
Reconstituting from raw audio files
Re: Reconstituting from raw audio files
<<<I have a folder of 146 b00###.au files>>>
http://audacityteam.org/forum/viewtopic.php?f=12&t=1253
I think he's blowing smoke. Until someone posts exactly how they got it to work, I'm going with you can't do it. Especially since I know that at least two of those files are graphic files, not sound.
http://audacityteam.org/forum/viewtopic ... r+au+files
