Hi Mike,Mike.Devos2 wrote:... the bit about connecting my regular good old trusty Technics analog pick-up, earthed to my PC chassis.
glad you found a way to get it all working.
A quick additional note on connecting a turntable to a PC: unless the TT itself has a built in phono preamp delivering line level output, then you will need a phono preamp between the TT and the PC. Otherwise you will not get the necessary RIAA equalization. In which case you will earth the TT to the pre-amp rather than the PC.
And yes, I am very ignorant of Vista - intentionally so at the moment. When I bought my laptop last year I specifically insisted that Dell downgrade the O/S to XP-Pro (and from the many Vista problem postings on the forum, very glad that I did that).
But indeed, thanks to Bam for the Vista info - this is me writing it down so that if and when I move to Vista or W7 then I will be fore-warned and fore-armed
Mr. Waxy Fonograph
