no wave out mix option
annwyn
Post by annwyn » Mon Oct 29, 2007 7:36 pm
I've installed audacity on my computer from the web but i have no wave out mix option on it , i've tried a couple of other versions of audacity too but none of them worked . Does anybody know why is this happening and what i should do ?
waxcylinder
Re: no wave out mix option
Post by waxcylinder » Tue Oct 30, 2007 11:42 am
The input options available to you in the drop-down are entirely dependent on your particular soundcard and its drivers. Sometimes upgrading the driver software to the latest versions increases the options (search t'interweb for your latest drivers).
annwyn
Post by annwyn » Tue Oct 30, 2007 9:32 pm
they didn't say anything like that on the website but i guess i could try , what exactly do you think i should upgrade?
waxcylinder
Post by waxcylinder » Wed Oct 31, 2007 10:58 am
annwyn wrote:what exactly do you think i should upgrade?
Upgrade the device drivers for your soundcard - this is the software that makes your soundcard work/talk to the computer.
You need to find out the make/model of soundcard that you have and then Google your brains out to find the latest device drivers for that card.
