mp3 export error...need .dll file!!!
princesultan
i try to export to an mp3, then i get an error message saying i need to locate the lame_enc.dll file. i downloaded the software from the LAME webpage but i have no idea what to do. does anyone have any suggestions?
Re: mp3 export error...need .dll file!!!
Do you have your computer set to show you file extensions?
Anyway.
# Go to the LAME download page.
# Under "For Audacity 1.2.6 and 1.3.3 on Windows", left-click on the link "libmp3lame-win-3.97.zip" and save the zip folder to anywhere on your computer.
# When you have finished downloading the ZIP folder, unzip it and save the file lame_enc.dll that it contains to anywhere on your computer.
# The first time you use the "Export as MP3" command, Audacity will ask you where lame_enc.dll is saved.
So you have the zip file, right--the one you downloaded?
What happens if you just double cllck on it? Does it start opening up into another file or folder?
Anyway.
