import mp3/export mp3
whatthecello42
Post by whatthecello42 » Mon Aug 24, 2009 11:40 pm
If I import an mp3 file to audacity, then export a section of it as an mp3 file, will there be any loss in sound quality in the file?
Re: import mp3/export mp3
Post by kozikowski » Mon Aug 24, 2009 11:46 pm
Yes. Twice. Audacity will not edit an MP3 file. It converts to an internal uncompressed format and then re-compresses at the other end.
You want one of the MP3 editors that doesn't have to re-encode. You don't get fancy-pants effects, tools, and editing with those, but it may be enough.
whatthecello42
Post by whatthecello42 » Tue Aug 25, 2009 12:09 am
Is there a freeware mp3 editor that does not have to encode?
Post by kozikowski » Tue Aug 25, 2009 12:50 am
I believe there are several for WIndows, yes.
waxcylinder
Post by waxcylinder » Tue Aug 25, 2009 8:07 am
MP3cut is often recommended on the forum for this task.
