Convert mono to stereo
NICKL
Post by NICKL » Mon Aug 24, 2009 9:26 pm
Hello all,
I am new to audacity 1.2.6..
I have music that was recorded with only a mono microphone.
The music only plays out of the left speaker.
How do i create stereo from mono with this software?
Any ideas?
Thanks!
Re: Convert mono to stereo
Post by kozikowski » Mon Aug 24, 2009 10:00 pm
<<<How do i create stereo from mono with this software?>>>
No. First you need Audacity 1.3. You can install both versions as long as you only use one at a time.
Load your show. Track > Add Track. Select and copy the original song. Select the new track and paste.
Using the tools on the left of the top track > Make Stereo Track.
Export the new stereo show.
I would warn you to change Audacity preferences to 44100, 16-bit, Stereo before you do any of this. Audacity 1.2 in particular has unfortunate defaults.
NICKL
Post by NICKL » Mon Aug 31, 2009 1:10 pm
Hi Koz,
thank you so much for your help.
that worked out well for me.
thanks once again,
Nickl
