I need help with seperating the audio!
tapirtoon
Post by tapirtoon » Sat Aug 22, 2009 5:33 pm
In audacity as soon as I copy and paste a sound clip they merge together on the same track! I want them to be seperate on the same audio track! How can this be done?
Re: I need help with seperating the audio!
Post by kozikowski » Sat Aug 22, 2009 5:53 pm
When you paste a sound clip into an existing performance, what's supposed to happen is the clip will start at the cursor location and play until the end, and then the rest of the original performance will play. Paste should cut a hole in the performance and drop the clip in.
Isn't that what happens to you?
