Retrieved Files
OctavianIII
Retrieved Files
Post by OctavianIII » Mon Aug 17, 2009 2:53 pm
I have been using Audacity for three weeks to record our Church's Sunday Message. Before I had a chance to save the project, an error occurred and the message came up that the files were not saved but could be retrieved. I was able to locate the file, however there are over 1,200 files that need to be added. Not wanting to do this, I am hoping there is a way to select all files and somehow restore the project. The files appear to be retrieved in the correct order. The down side is one track is voice while the other is instrument. Any help would be appreciated......
Re: Retrieved Files
Post by kozikowski » Mon Aug 17, 2009 4:43 pm
An Audacity Project consists of the AUP project manager (not a sound file) and about a million capture snippets which, as you're finding out, aren't really good sound files, either.
You can sometimes put them back together with the crash recovery tools.
Crash Recovery
http://audacityteam.org/wiki/index.php? ... shRecovery
OctavianIII
Re: Retrieved Files
Post by OctavianIII » Mon Aug 17, 2009 5:38 pm
I was able to use the recovery tool and it worked perfectly. Both tracks were restored and with a few copy/pastes, I was able to do my usual editing.
Thanks!!!
waxcylinder
Re: Retrieved Files
Post by waxcylinder » Mon Aug 17, 2009 5:39 pm
You may find it advantageous to upgrade to the Beta vn. 1.3.8 - 1.3.x has MUCH better recovery handling.
