I.E. cannot open the Internet Site
guzie
Post by guzie » Fri Oct 26, 2007 10:05 pm
When I try to download audacity at:
Internet Explorer cannot open the Internet site
http://sourceforge.net/project/download ... -1.2.6.exe
Operation aborted
Not sure where that problem lies......
Thanks From
Paul Guzman
epauley
Re: I.E. cannot open the Internet Site
Post by epauley » Sat Oct 27, 2007 2:44 am
I am having the same problem. Help is appreciated.
tory
Post by tory » Sat Oct 27, 2007 9:37 pm
I am having the same problem, and am not sure if it is the firewall in my new computer, or a problem with audacity. Have you heard anything?
Tory
epauley
Post by epauley » Mon Oct 29, 2007 3:29 am
According to my web browser, Explorer is blocking the site - as an imposter site. :?
tory
Post by tory » Mon Oct 29, 2007 6:04 pm
How can I get past explorer blocking the site??? Please help.
Tory
epauley
Post by epauley » Tue Oct 30, 2007 12:55 am
I have tried turning off protection within Explorer but without success. So far, no member is jumping in with a solution.
epauley
Post by epauley » Tue Oct 30, 2007 1:15 am
I went to the following website and pressed the download button.
http://www.techspot.com/downloads/3194- ... -beta.html
Once I started downloading audacity (beta version for xp and Vista), I still got the “site is blocked" message. However, afterward I was able to right-click the yellow bar at the top of page and select “download” file. I now have the beta version installed. Hope this helps.
jeeper1
Post by jeeper1 » Tue Oct 30, 2007 2:28 am
I went to download.com and successfully downloaded audacity there. Goodluck
tory
Post by tory » Tue Oct 30, 2007 11:47 pm
I have had no luck with download.com so will try the site that epauley suggested. I am not too impressed with the underwhelming lack of response except for a couple of members. It is so frustrating as I used audacity daily on my old computer.
Tory
tory
Post by tory » Tue Oct 30, 2007 11:58 pm
I was able to download the beta version. What is the difference? I see that I cannot open the save audacity files from my old hard drive, different version I guess. The sound wave appears as a straight line with a few little bumps on it. I'll have to play around with the settings.
Thanks so much
Tory
