Doesn't play back on as MP3 or Wav on Itunes nor Media playe
tubajazz
Post by tubajazz » Tue Aug 11, 2009 2:17 pm
Hello,
I recently Installed Audacity on my computer. It records from my tape player and plays the song back on Audacity. However when I export to Wav or MP3, the song doesn't play back in the media player nor Itunes. It shows the song I recorded and has the counter, but it is completely Mute.
What do I do?
Thanks,
David
Re: Doesn't play back on as MP3 or Wav on Itunes nor Media p
Post by steve » Wed Aug 12, 2009 2:57 am
What format are you Exporting the recording as?
Is the format supported by your media player?
tubajazz
Post by tubajazz » Wed Aug 12, 2009 7:42 pm
WAV or MP3. And yes, ITunes and Windows does support WAV and MP3 files.
Post by steve » Thu Aug 13, 2009 1:27 am
tubajazz wrote:WAV or MP3
What about the bit depth / sample rate?
tubajazz wrote:And yes, ITunes and Windows does support WAV and MP3 files.
I'm not sure that they support 24 bit or 32 bit files.
Make sure that you export as 16 bit 44.1kHz and then try to play them.
waxcylinder
Post by waxcylinder » Thu Aug 13, 2009 9:57 am
44.1kHz 16-bit PCM Stereo WAVs exported from Audacity certainly load and play in my iTunes libraries and on both my iPods.
