I have asked about this on the Native Instruments support forum too, but I haven´t received a response yet and I think this probably has more to do with Audacity then it has to do with Native Instruments. (For the Native Instruments support forum post see: http://www.native-instruments.com/forum ... hp?t=91010)
I want to record with a 96000Hz sample rate. When I set the sample rate in audacity to 96000Hz and in the audio 4 dj control panel to 44100Hz, it all works fine and i shows a nice spectrum in audacity. But when I select any other sample rate in the audio 4 dj control panel audacity gives me an "Error while opening sound device. Please check the input device settings and the project sample rate."
Visual representation of the problem:
Situation 1, working (96khz in audacity, 44100hz in audio 4 dj control panel):
audacity
audio 4 dj control panel settings
audacity working
Situation 2, not working (96khz in audacity, 96khz in audio 4 dj control panel):
Same audacity settings
Failure
Thanks alot if someone could help me out with this.
