When editing sound files, it would help if I could either see the time currently being played (i.e. a play clock) or be able to place a marker in the sound file while it is playing. This would help in selecting the area I want to delete. Do either or both of these features exist already in audacity?
I read some posts on "scrubbing" which seemed similar to what I want to do and didn't see any sign that either of these features was present.
Display
paulenorrisii
Re: Display
The "Scrubbing" feature is currently absent in Audacity, I can't say if that will always be the case though.
But you can certainly add a marker to a project while it's playing, press [ctrl]+m to create one at the current playback position (only while it's playing) or press [ctrl]+b to create one at the cursor position (not the same thing).
I have no idea why there are two options, but the [ctrl]+m one is the one you seem to need.
Re: Display
No scrubbing. Sorry.
On the version I have, the cursor position time is called out at the bottom left of the window.
[Cursor: 1:43.243 min:sec]
Re: Display
I see what the problem is. The number doesn't follow you unless you explicitly move the cursor.
That whole selection/cursor/marker thing could use some serious work.
Re: Display
I opened a saved project (wanted to finish recording an LP) and from the cursor position, to the end, the visible part of the audio (the waves) are missing. When I reverse, and click play, there's sound, but I can't see where the breaks are to enter labels. Suggestions?
Thanks
Thanks
Mark Storey
Baby Boomer w/lots of old albums to record
waxcylinder
Re: Display
Mark, you should really have started a whole new thread for this.
It is certainly odd behaviour - AFAIK the wave forms are drwan from data hed the .aup project file whereas the sound comes from the little .au files stored in the project folder - so it sounds as though uyour .aup file has somehow become damaged.
Two work-arounds:
1. find the intertrack gaps by ear
2. re-record the LP into a fresh Audacity project.
Two work-arounds:
