time shift tool
thunder
time shift tool
Post by thunder » Sat Aug 01, 2009 6:51 pm
when I try to use the time shift tool,it doesn't seem to work when I am playing the tracks so I can line up the beats properly, it works on pause or stop I have to hear it to line it up right. The manual says I am supposed to be able to do this..what do I need do to to correct this? Am I missing something here?
Re: time shift tool
Post by steve » Sun Aug 02, 2009 7:19 pm
The time shift tool will only work when you are in "Stop" mode.
In Audacity 1.3.x you can use Ctrl+M to place a marker while the audio is playing. Beats are usually visible as peaks in the waveform display.
thunder
Re: time shift tool
Post by thunder » Mon Aug 03, 2009 9:27 pm
Thanks steve
