Hello,
I can't seem to find documentation on Command Line controls for audacity, other than people mentioning that they are very limited. Is there anyway to specify to read in raw data at 8khz from the command line? I can accomplish this manually, but am trying to launch the program from a system call in a matlab program.
Thank you
Command-Line Control
psustudent1
Re: Command-Line Control
Code: Select all
audacity [ AUDIO-FILE ]http://ccrma.stanford.edu/planetccrma/m ... ity.1.html
psustudent1
Thank you, I thought this might be the case.
