Copying Issues
ralphyj
Copying Issues
Post by ralphyj » Sat Jul 18, 2009 7:56 am
Whenever I copy something to another track, it's sped up. How do I stop this?
Re: Copying Issues
Post by steve » Sat Jul 18, 2009 1:03 pm
Upgrade to Audacity 1.3.8
BTW, Audacity is a multi-track editor - there is rarely any need to copy from one track to another - just use multiple tracks. Tracks will be mixed together when you Export your finished audio file.
ralphyj
Re: Copying Issues
Post by ralphyj » Sun Jul 19, 2009 8:37 pm
it just randomly stopped speeding it up today, it it does it again, I'll come back...
ralphyj
Re: Copying Issues
Post by ralphyj » Sun Dec 27, 2009 11:13 am
It's happening again, if I copy a track to another track, the audio is sped up. How do I fix this?
As you can see in the image below, the tracks circled are the same piece of audio, but when copied, the audio is much smaller, as in, it has been sped up.
waxcylinder
Re: Copying Issues
Post by waxcylinder » Sun Dec 27, 2009 11:16 am
What project rate and bitrate do you have your Audacity Preferences set to?
ralphyj
Re: Copying Issues
Post by ralphyj » Sun Dec 27, 2009 11:26 am
I have no idea. How do I find that out?
waxcylinder
Re: Copying Issues
Post by waxcylinder » Sun Dec 27, 2009 11:36 am
Project rate should be shown at the bottom right hand corner of your Audacity window.
In 1.2.x go to Edit > Preferences > Quality - there you can see (and change) samplse rate and sample format.
ralphyj
Re: Copying Issues
Post by ralphyj » Tue Dec 29, 2009 12:05 pm
Project Rate: 44100
Bit Rate: 32-bit float
Will that help?
Re: Copying Issues
Post by steve » Tue Dec 29, 2009 1:24 pm
In Audacity each audio track may have its own sample rate.
When you record a track it will use the default rate for the Audacity Project, but if you Import an existing file the sample rate of that track will be whatever the sample rate of the file was. For example, if your project sample rate is 44100 and you Import (or drag and drop) a file with a sample rate of 22050, the sample rate of that track will be 22050.
Audacity 1.2.x uses just one sample rate for a track. This means that if you copy and paste part of a track into a track that has a different sample rate, the pasted audio will play at the wrong speed (it will play at the same sample rate as the track is set at).
As said earlier, it is rarely necessary to paste clips into the same track as Audacity is a multi-track program, but Audacity 1.3 is able to support multiple audio clips in the same track at different sample rates.
