Control from a separate program
Does anyone know if it is possible to send commands to audacity from my own program? By commands I mean: create a new file, start and stop recording, and saving the file. Thanks for your help.
Re: Control from a separate program
You can try it. Audacity uses timing to do stuff and that kills network operation, and may kill you, too.
I guess a better question is can audacity be controlled through a script or on the command line?
