can't hear the recording until I press record
Hi, I'm Camsky and just joined the forum. I just got a usb turntable and it works fine with Audacity except I can't hear the recording until I press record. Makes it hard to know when to start. Any advise? Thanks so much.
waxcylinder
Re: can't hear the recording until I press record
just click once in the recording meter bars - this will turn monitoring on. This is poorly documented and not very obvious (but easy when you know how).
Thank you soooo much!
Please tell me this is different in 1.3 / 1.4...
waxcylinder
No Koz, it's still just the same.
I don't think the developers perceive it as a problem - despite email discussions and postings in the Feature Requests in the Wiki. My old R2R tape deck and later cassette decks all had monitoring on all the time IIRC - so if a signal was present it showed on the meters. I don't mind the Audacity meters having an on/off but there should be a visual cue to indicate the state and an obvious "something to click on" to change the state.
There are a couple of refrences to how to turn on monitoring in the 1.4 manual (under development) - but these are well hiidden deep in the middle if articles like: "Recording with USB turntables" and "Tutorial - Copying tapes, LPs or minidiscs to CD" and in the FAQ in the manual under "Why can’t I hear what I’m recording?". But I don't think any of these are at all obviouus and in no way make up for the of the limitations GUI as discussed above.
