Post
by kozikowski » Mon Jul 13, 2009 2:47 pm
Interesting combination of errors. How are you recording this? Capture file and play locally? Record Mix-Out?
Two computers? Cable Box and computer?
jecs110
Post
by jecs110 » Tue Jul 14, 2009 12:21 am
input is directly connected to the output with a double male audio cable,
i have a spliter on the output so i can connect one to my pc and also connect my headset to the other so i can hear what i record
all settings are on default
using Realtek built in s/c
Post
by kozikowski » Thu Jul 16, 2009 2:15 am
Does your PC setup say you can switch one input connector between High Level Line-In and Low Level Mic-In? Or alternately, do you have a Line-In connector on your sound card -- sometimes blue? If all that is no, you are greatly overloading your sound card.
The Mac people can do that cable trick, they have matching Line-In and Line-Out...but not you.
You may be stuck capturing the data stream inside the computer.
http://wiki.audacityteam.org/index.php? ... e_computer
...which may sound better anyway,.
jecs110
Post
by jecs110 » Tue Jul 21, 2009 1:41 am
tried Line-In, but same junky sound,
i was thinking maybe i was overloading the sound card and u mentioning it pretty much confirms it,
hehe but yet i dont see myself going to the store to buy myself a soundcard, think ill stick with good ol' AC'97
thnx again fer yer input
