I use Audacity in a very basic way -- I just record my old albums and make MP3s and CDs. Suddenly, while I'm recording I get an echo on the voices. The recording itself is fine -- this is the sound that I'm listening to through my computer speakers. It's very annoying, especially since I like to listen while the album is recording so that I can divvy up and label the tracks.
Does anyone know what might be causing this problem and how to fix it?
echo while recording
Re: echo while recording
You're probably listening to Stereo Mix (the computer output) and the Line-In at the same time. One will be late compared to the other.
Sometimes you get get this by having too many things turned on in the Windows Control Panel.
