Sound Input Error
LightningNinja2
Sound Input Error
Whenever I try and record audio I keep getting a message that says "Error while opening sound device. Please check the input device settings and project sample rate." how do I get rid of this message and/or fix the program. And I have already uninstalled and reinstalled the program. And on occasion it actually works.
Re: Sound Input Error
And what occasions are they?LightningNinja2 wrote:And on occasion it actually works.
memoryblackout
I am so sick of that error message, someone PLEASE tell me why it does this... and how to fix it.
waxcylinder
It often happens because Audacity can't recognize your soundcard - or because you have specified the wrong number on channel inputs in your preferences (which then don't match with what your soundcards supports).
Viviengwtw88
I use Vista Home Basic and have exactly the same error message when I push the record button. Did you figure out what is wrong. Please let me know if you find a solution.
As waxcylinder said - look at your sound-card settings and ensure that you have a valid audio device (sound card) selected for both recording and playback.
(Edit menu > Preferences > Audio I/O)
If your sound card is not available as a recording device, open the control panel and enable a recording input - see here for how: http://wiki.audacityteam.org/index.php? ... ng_devices
