no output during recording
mark42
Post by mark42 » Tue Jun 30, 2009 7:31 pm
my laptop crashed and i re-installed everything including audacity 1.2.6. prior to the crash i would get audio output as it was being recorded.......not now. i can play a recording back i get normal audio from my speakers. my os is windows xp pro sp3. jbl external speakers and realtek audio output. is there some magic switch somewhere that has to be enabled? my recording setup is behind me and i use the sound as a cue for pausing or stopping a recording while working on the computer in front of me. help!
Re: no output during recording
Post by kozikowski » Tue Jun 30, 2009 7:36 pm
<<<is there some magic switch somewhere that has to be enabled? >>>
Yes. It's "mix out" or something like that. It's not a default. You need to go looking for it.
Windows Control Panel
mark42
Post by mark42 » Wed Jul 01, 2009 7:05 pm
problem solved. i had to enable software play through on the audio i/o tab in preferences.
Post by kozikowski » Wed Jul 01, 2009 7:11 pm
That, too. Thanks for posting back.
