Hello!
I would like to use Audacity to trim mp3 file without re-encoding.
I know about the usual way: select, crop and export as mp3. But I don't want to loose the quality of the file and re-encode the part of mp3 again.
Thank you!
Mp3 trim without re-encoding
Re: Mp3 trim without re-encoding
I think mp3DirectCut will do what you want: http://mpesch3.de1.cc/mp3dc.html
Thank you, enderbyte! Your solution is great, I will use it.
But is there an open source solution?
I didn't see a price posted...?
As the author states on the home page:
"freeware
no nags · no spyware · no registry usage"
However, it is not open source.
"freeware
I have never head about freeware to trim mp3 without re-encoding. Seems like all free programs recompress files and loose quality. When I needed to trim audio and save all its quality, I just used a trial of Mp3 Cutter & Joiner. Appreciated its feature of automatic removal of silence. I really recommend this software.
Mp3split will trim without re-compressing.
It's free and open source (GPL) http://mp3splt.sourceforge.net/mp3splt_page/home.php
