a few questions...
theeshaneomac
a few questions...
Post by theeshaneomac » Wed Oct 17, 2007 11:19 pm
1. I have been trying to download plug-ins for Audacity 1.2.6 and they are not being recognized in the program. I have Windows Vista, which may be the problem. If that is the problem can someone direct me to a site that has Vista compatible plug-ins? If Vista is not the problem I would like to know what I am doing wrong. So far I am just unzipping the files and dragging the .dll files into the plug-in file of Audacity but they do not appear even when i restart my computer.
2. Can someone explain FTT Filtering indepth to me?
3. What order should I apply clean up effects like Click Removal, Compression, and Noise Removal?
Thank you
alatham
Re: a few questions...
Post by alatham » Fri Oct 19, 2007 3:05 pm
theeshaneomac wrote:1. I have been trying to download plug-ins for Audacity 1.2.6 and they are not being recognized in the program. I have Windows Vista, which may be the problem. If that is the problem can someone direct me to a site that has Vista compatible plug-ins? If Vista is not the problem I would like to know what I am doing wrong. So far I am just unzipping the files and dragging the .dll files into the plug-in file of Audacity but they do not appear even when i restart my computer.
What kind of plugins are they? If they're VST plugins you need an extra file available here (the VST enabler):
http://audacityteam.org/download/plugins
If they're not VST plugins then let us know more about where you got them from.
Newer versions of Audacity don't include the FFT filter because it serves the same purpose as the Equalization effect and is harder to use.
The FFT filter is just an EQ with the frequency displayed linearly instead of logarithmically. I don't know how in-depth you want (I could write at least a page worth of text on it, but I don't want to). You can look at the wikipedia article on the Fast Fourier Transform if you really want to:
http://en.wikipedia.org/wiki/FFT
There is no correct order to do anything in the audio world.
Most people would do Click Removal -> Noise Removal -> Compression though.
