Recording too fast
rjcritter
Re: Recording too fast
Post by rjcritter » Wed Jun 03, 2009 8:22 pm
Ok. I think I understand now. DirectSound is just an alternate engine than Mulitmedia Engine (MME). I have all the latest updates do directx, I think. Maybe I should check everything out to make sure that all my programs are running with the same credentials or plug-ins or whatever they need to ensure the same result.
I will say this. I still did my show today, but I went back to using WME and when I recorded with Audacity everything went back to normal. When my timer went off I was exactly 1hr and 2sec with Audacity (I start it 2sec before my timer). I didn't change anything with Audacity. I'm still using DirectSound: SB Live! 24-Bit. When I have time I would like to do some experimenting with the SHOUTcast Source again. If I do I'll let you know the results. Keep an eye out for anyone with the same problems.
It's been great chatting. Thanks for the help and info. If you get time, check out http://www.ritterfarms.com/radioshow.html. We keep the last week's shows archived on the radio show page of our website.
