Importing from iTunes
flapjack47
Post by flapjack47 » Mon Jun 01, 2009 2:56 pm
There is a tutorial in Wikipedia concerning how to import from iTunes into Audacity:
http://audacityteam.org/wiki/index.php? ... rom_iTunes
I didn't think this was possible? At least, every time I've tried it imports it as some unrecognizable audio. Any tips?
allencmcbride
Re: Importing from iTunes
Post by allencmcbride » Mon Jun 01, 2009 5:53 pm
Are you trying to import copy-protected music? If so, which of the tutorial's methods are you trying to use? --Allen
flapjack47
Post by flapjack47 » Mon Jun 01, 2009 11:18 pm
Well, even if I"m downloaded songs from a disc into iTunes, it won't let let me then load them into Audacity. So I guess it's putting them in a format which is not Audacity-friendly (?)
allencmcbride
Post by allencmcbride » Tue Jun 02, 2009 1:37 am
For Audacity version 1.2, the tutorial you linked to describes how to convert songs to WAV from within iTunes, and then open the WAV file in Audacity. Is that how you're trying to do it? Where exactly do you run into trouble? --Allen
Post by kozikowski » Tue Jun 02, 2009 1:51 am
Unless you changed it, iTunes changes all incoming music into Apple AAC format which is efficient and iPod friendly, but isn't compatible with anything.
You can change that. iTunes Preferences > Import Settings > WAV or AIFF Auto. Either of those should drop right into Audacity or any other audio program. My preference is WAV because that's acceptable on all three computer types.
flapjack47
Post by flapjack47 » Tue Jun 02, 2009 11:16 pm
It worked! I got it! I"m excited. And here all this time my co-workers convinced me that I "had" to burn it to disc.
