McAfee causing drop outs
drawdlaniger
Post by drawdlaniger » Mon Jun 01, 2009 8:01 am
Is there any way I can record either from internet music sites or CD's with McAfee security system still active. Too avoid experiencing these drop outs.
They vary according to how long Audacity has been switched on.
waxcylinder
Re: McAfee causing drop outs
Post by waxcylinder » Mon Jun 01, 2009 8:43 am
Can you set your McAfee so that it "trusts" and therefore ignores files with .aup and .au extensions?
drawdlaniger
Post by drawdlaniger » Tue Jun 02, 2009 11:08 am
Thanks for that suggestion regarding .au and .aup extensions.
I know how to allow access to various programmes in McAfee. But I am at a loss on how to identify these particular extensions
waxcylinder
Post by waxcylinder » Tue Jun 02, 2009 1:57 pm
Sorry I can't help you further - I also run McAfee and hada quick poke around and likewise couldn't see any seetings for this.
But I am lucky in that McAfee on both my PCs does not give this problem recording with Audacity.
You might want to consider looking at a piece of software called TotalRecorder (often recommended by one of the very regular posters on the forum, kozokowski). You could try using TR for the audio capture and then use Audacity for the editing and export.
Post by steve » Tue Jun 02, 2009 10:39 pm
If you are disconnected from the internet while you are recording, and you are working on a virus free computer, and you are not connecting external drives, USB memory sticks, or inserting disks (completely blank CDs are OK) then it is quite safe to temporarily disable your anti-virus program. At work I use a computer that has no anti-virus programs at all, but it is a standalone PC with no way of inputting data except through the keyboard, mouse and sound card.
drawdlaniger
Post by drawdlaniger » Wed Jun 03, 2009 10:52 am
I went into my McAfee security box and highlighted Computer and files configure, found Buffer overflow protection. and unticked.
so far no drop outs
