How do i alter the play speed on audacity?
nunybw
Post by nunybw » Thu May 28, 2009 9:14 pm
I have imported a song into audacity but it speeds it up so its over in a second. A track that should go on for several minutes only fills one screen. Any ideas?
waxcylinder
Re: How do i alter the play speed on audacity?
Post by waxcylinder » Fri May 29, 2009 9:59 am
You are almost certainly trying to import a file type that Audacity does not support. Audacity Supports WAV, MP3, OGG and FLAC & MP2 in 1.3.
The screech is Audacity 1.2's inelegant way of telling you that it can't handle the file type you've given it - in 1.3.x a more appropriate and informative error message appears.
If this is the case you have two basic options:
1. find and use some converter software to convert your file to a type that Audacity supports
2. play the file in any music software that supports that particular file format and record it in Audacity.
stevethefiddle wrote:There's a free program called SUPER by erightsoft that can convert most media file types. If you can convert the files to WAV files that should fix the problem.
