if i export a song to mp3 or wav and try to play it with vlc or media player there's no sound.
if i import it back to audacity there's sound again....????
what do i do???
export to mp3 or wav, no sound...
rebelgirl83
rebelgirl83
Re: export to mp3 or wav, no sound...
and i just discovered that vlc or media player are unable to produce sound with any other audio/video file on my comp. ?!?
since i installed audacity!!!
what's up with that?
Did you try recording internet audio after you installed Audacity? Maybe you installed or plugged in a USB sound card or device? Vonage or Skype telephone calls? USB Turntable? All of those reset the Windows sound services. In the case of a USB capture device, Windows will try to send sound back to the device as well as capture the sound coming back. The device has no idea what to do with that and the sound on your computer drops dead.
Windows Control Panel
rebelgirl83
aha
i see! its a usb turntable and if i just unhook the usb cable the sound works again!
thanx so much!!!
thanx so much!!!
<<<if i just unhook the usb cable the sound works again!>>>
Yes. You don't have to do that, you can open the Windows Control Panels and make sure Windows is set to play back to the speakers and not the turntable. That will save you from crawling behind the turntable every time you want to record.
rebelgirl83
thanx! its all fixed now!
