No sound in windows mediaplayer
hengst
Post by hengst » Sat May 16, 2009 12:21 pm
After installing Audacity I have no sound in Windows Mediaplayer what am I doing wrong?
Re: No sound in windows mediaplayer
Post by steve » Sat May 16, 2009 2:08 pm
Do you have a USB audio device plugged in (for example a USB turntable)?
If so, then Windows has set the default audio device to be the USB device.
You have then 2 options:
1) Unplug the USB device (may require reboot)
2) Go into the Windows control panel and in the Sounds and Audio devices section, set the default playback device to your sound card (better solution).
