Pardon my first time post.
Does any one know if Audacity can be used on a Linux/Apache server controlled with PHP via command line?
I want to use it for an online web application with Flash as the GUI
Any links, samples or suggestions would be appreciated.
Thanks in advance,
Typeguy
Audacity from Server using PHP and Flash?
Re: Audacity from Server using PHP and Flash?
Audacity is designed as a desktop application. There is very little command line support (other than opening a named file).
