I have recently stumbled on Audacity after using a different multitracker for quite some time.
Audacity is so wonderfully intuitive, simple and easy to use, and yet it has everything I need.
Once I looked under the hood I realized it was capable of doing much more than I originally thought.
I have had no stability issues and my CPU usage is down.
The help files are concisely and clearly written and are quite easy to understand.
This program will allow me to get on with making music, instead of struggling
with the steep learning curve and problems inherent in so many of these type programs.
The more I use this program the more I like it, I wish I had discovered it soooooner.
You guys should be commended for the great work you are doing here.
Thank You So Much
Ted
