Started to not play anything during rec
laysie
Post by laysie » Tue Sep 06, 2011 7:12 pm
Hey,
I installed audacity then I tryed installing an autotune feature...
Well sometime in the last few days my audacity won't play the track I want to listen to and record over.
Is there a link to troubleshoot this and fix it? I done looked and clicked the things in audio i/o etc and that didnt work,.
Re: Started to not play anything during rec
Post by kozikowski » Tue Sep 06, 2011 8:10 pm
You posted in a portion of the forum where we can't tell either the computer you have or the version of Audacity, but, in general, you go into Audacity Preferences and select "Play tracks while recording new ones."
Restart Audacity when you make changes like that.
Post by steve » Wed Sep 07, 2011 11:51 pm
laysie wrote:I installed audacity
Which "Audacity"? version numbers go from 1.0 to 1.3.13 and there are "ANSI" versions and "Unicode" versions. Look in "Help > About Audacity" to see exactly which version you have.
laysie wrote:I tryed installing an autotune feature...
What "autotune feature" was that?
How did you install it?
Did you have the problem before installing it, or only after installing it?
What operating system are you using?
