dividing tracks
dividing tracks
I just got an ion turntable-hooked it up and recorded an album. but i can't get it to divide the album into tracks. i can view it in the (fit project into window) i can insert my divide but when it comes to naming that track or getting the little red flag to appear--i'm lost. the software that i'm using is 1.2.4
Re: dividing tracks
never mind I got it now.
amretired2
Re: dividing tracks
Wish to divide the various albums that are recorded via Audacity. When I select the Project menu, and then Add Label at Selection, I am able to type in the Label for the first track, the text is shown. When I go to repeat for the next track, the first one is being overwritten and appears lost. Repeated attempts on different albums, get the same results. What am I doing wrong? Please advise.
I'm using Version 1.2.6 in Windows XP SP2.
Earl at [email protected]
Re: dividing tracks
amretired2,
Audacity 1.3.3 handles labels better than earlier versions, you will probably have better luck using that version.
I'm not sure what you're doing wrong. For me, it's a matter of click on the track, pressing [ctrl]+b (add label), typing in a label, then repeating.
Perhaps you aren't clicking on the new label to move the cursor there? Be aware that Audacity doesn't display a cursor like it should, 1.3.3 is better about that, but it's still a little confusing.
