No sound on Audacity 1.2.6
Re: No sound on Audacity 1.2.6
Post by kozikowski » Wed Feb 13, 2008 3:33 am
Here. I made a new one. You don't get the green flashing lights?
http://www.kozco.com/audacity/AudacityPanelStandard.jpg
Jociaa
Post by Jociaa » Fri Sep 26, 2008 12:58 pm
i can't here my sound every one says you have to change the 1/0 thing were is that button or i don't get the spickey lines i get a straight line
Post by steve » Fri Sep 26, 2008 4:04 pm
Jociaa wrote:every one says you have to change the 1/0 thing
I think you mean I/O (Input/Output) rather than 1/0 (one zero).
Open Audacity
Click on "Edit" in the top menu
Select "Preferences" (at the bottom of that menu)
The "Preferences Window" will open - it has several tabs
Sect the tab that says "Audio I/O" (this is the first tab, so it will probably be selected already.
To save typing, we usually abbreviate this to "Edit > Preferences > Audio I/O"
rae
Post by rae » Tue Mar 31, 2009 7:45 pm
Over the past week or so I've been recording things on audacity through the microphone built into my laptop (running vista home basic) and they've been playing back fine and all, but now whenever I go to play them back, I get the flashing green lights, the cursor thingy moves, the blue bars are all there, but no sound comes out. The warning/alert noises are still working, and my sound works fine on everything else on my computer but no matter what I try (restarting, changing the I/O settings), nothing seems to be fixing it. Any ideas on what may be the cause of this and how I can fix it?
Thanks guys.
