"complete user's manual"
mcpherron
Post by mcpherron » Wed Dec 12, 2007 8:28 pm
How do I print off a copy of the Manual? It appears to be incomplete, though the images seem to all be there.
Re: "complete user's manual"
Post by steve » Thu Dec 13, 2007 1:27 am
http://audacityteam.org/audacity-manual-1.2.zip
(To use the downloaded manual, unzip it and then open the "index.html" file.)
flopwich
Post by flopwich » Thu Dec 27, 2007 11:27 pm
I downloaded the manual, unzipped it, and clicked on index.html. The manual opens just fine, but the links to all the images are broken. I can't see any of the images. Can you help me out here? Thanks.
Post by steve » Fri Dec 28, 2007 3:27 pm
If you are on Windows, you may not have actually unzipped it. Just opening the file with Windows does not unzip the whole thing, therefore links will be broken. Try using WinZip or IZArc to unzip it to a new folder, then it will work. (IZArc is similar to WinZip, but it's free).
